KB86818
Published: December 12, 2023
False errors after device reboots in PAC Redundancy Manager
All versions
When performing functions that require a device reboot in PAC Redundancy Manager (such as IP address configuration or firmware download), you may encounter a false error (red X) in the Progress window that indicates the device did not restart or is not running when the device did restart successfully and is running.
Use PAC Manager to verify the device status and ignore the false error (red X).
