KB86824
Published: December 12, 2023
Cannot clear error messages on backup controller in PAC Redundancy Manager
R9.6a to current (may affect previous versions)
When you select Clear All Messages in PAC Redundancy Manager to clear error messages on the redundant (backup) controller, those errors may appear to clear but the error count does not change. If you select the ### error(s) button, the errors may reappear.
Using PAC Terminal:
- Under Configure Control Engines in the right pane, click Add.
- Create a non-redundant (Standard) entry for the controller.
- Select the new controller entry in the Control Engines list.
- Go to View > Messages > Clear All Messages.
For more information about PAC Terminal, review the
PAC Control User’s Guide (form 1700).
