KB86830
Published: June 30, 2017
PAC Display Configurator may crash when opening a recipe file that isn't properly formatted
Versions affected: R9.0a through R9.6d
Problem is fixed in version: R9.6e
PAC Display Configurator may crash when you click OK on the Select Recipe File dialog box (Tools > Edit Recipe File) to open a recipe file that has previously been edited.
  1. Open the recipe file in a text editor (for example, Notepad).
  2. Find the lines that read "/ End of File" and then delete all but the last one.  It will be at the end of the file.
You should then be able to open the file and edit it in PAC Display.
