KB86833
Published: September 18, 2017
PAC Display Runtime Operator can access controls on a popup window before logging in
Versions affected: R9.0a through R9.6e
R10.0b
If your PAC Display project presents a user login dialog box and a popup window when Runtime starts, the user can interact with the popup window (move it around, click its buttons, and so forth) before logging in. Instead, the user should be required to first log in.
In PAC Display Configurator, change the popup window to a child window (Window > Properties > Behavior).
