KB86851
Published: July 7, 2017
PAC Control Command-Line Interface (CLI) may display the "You are about to open a strategy" warning
Versions affected: PAC Control versions R9.6a through R9.6c
Problem is fixed in version: R9.6d
When you use the Command-Line Interface (CLI) tool's "/cdf" option with a strategy from a previous version of PAC Control, the "You are about to open a strategy saved using the <older> version of the PAC Control database" warning message is displayed.  Instead, no warning message should be displayed.
