KB86862
Published: September 20, 2017
Events that use OPC-UA tags don't work after groov restarts
GROOV-AR1-BASE
GROOV-SVR-WIN-BASE
GROOV-AR1
GROOV-AR1-SNAP
GROOV-SVR-WIN
GROOV-SVR-WIN-SNAP
R3.0a through R3.4b
R3.4c
An event that uses an OPC-UA tag displays a "Missing tag" error after groov restarts. Note that the issue happens when the tag is used only with an event (and nowhere else in the project).
Add a page to the project, and on the page, assign the OPC-UA tag to a gadget. It doesn't matter which kind of gadget you use—a Value gadget will work fine.
