KB86887
Published: August 27, 2017
PAC Display Configurator: Discrete On/Off text (Text In from Control Engine) is blank
Versions affected: R9.6a through R9.6e
R9.6f
In PAC Display Configurator, if you configure Discrete On and Off text ("Dynamic Attribute - Text In from Control Engine" dialog box), and then you close and reopen the dialog box, the On and Off text fields will be blank.
Note that if you don't reopen the "Dynamic Attribute - Text In from Control Engine" dialog box, you can save the project, and the text will be displayed during Runtime.
