KB86889
Published: August 27, 2017
On Windows 7 only, PAC Display Runtime crashes if sent an empty string
Versions affected: R9.0a through R9.6e
R9.6f
NOTE: This issue occurs only on Windows 7 (32-bit or 64-bit).
When a graphic is configured to send a string of user input (Graphic Dynamic Attribute > Send String > Prompt for data), PAC Display Runtime will crash if the operator doesn't type an entry before pressing the Enter key.
If you don't want to send any data when prompted, either press Cancel or enter at least one space.
