KB86926
Published: September 19, 2017
Implicit EtherNet/IP messages contain 0 for attributes of some analog modules
Versions affected: PAC firmware R9.4a through R9.5e
Problem is fixed in version: PAC firmware R9.5f
If configuration information for an EtherNet/IP assembly is stored in flash memory, after power-up, attribute data for some analog modules may be set to 0 (zero) in Target-to-Originator (T2O) implicit messages.
Do not store the assembly configuration to flash. Instead, use PAC Manager to clear flash memory of the brain or controller, and then, after power up, use EtherNet/IP Configurator to download the EtherNet OTG file.
