KB86947
Published: May 24, 2018
Values in PAC Display Runtime aren't updated while Runtime window is minimized
Versions affected: R9.6a through R9.6f
R10.0a
PAC Display Runtime doesn't update on-screen values that change while the Runtime window is minimized.
For example, if Runtime displays a value of 100 and you minimize the Runtime window, when you restore the window, the value displayed is still 100—even though the value changed in the meantime.
The issue happens only if the value changes while the window is minimized. If the value updates again after the window has been restored, the new value will be displayed.
If the value changes after the window has been restored, the issue corrects itself.
Another option is to close the window and then re-open it.
