KB86959
Published: September 26, 2017
mistic and SB-series serial brains go offline when used on the same serial port
SNAP-PAC-S1-FM
Versions affected: PAC firmware R9.0a through R9.5e
Problem is fixed in version: PAC firmware R9.5f
When mistic and SB-series (SB1, SB2) serial brains are mixed on the same serial port, I/O errors may occur and communication to the brains may become disabled.  It may not be possible to re-enable communication to the serial mistic and SB-series brains (I/O Units).
Don't mix mistic and SB-series brains (SB1 and/or SB2) on the same serial port.  Put SB-series brains on one serial port and mistic brains on a separate serial port.
