KB86961
Published: September 17, 2017
PAC Display: "-copy" is missing from the names of imported alarm points
Versions affected: R8.1a through R9.6e
R9.6f
When you import an alarm point from a subfolder (Configure > Alarm Points > Import button > Import from Subfolder), PAC Display Configurator doesn't append the alarm point's name with " - copy" if the original (exported) alarm point had a Reference Count of zero (0).
Use comma-delimited files to export and import alarm points.
