KB86964
Published: September 17, 2017
Network connections may be lost when PAC Display Runtime is running
Versions affected: R9.0a through R9.6e
R9.6f
Note: This issue affects only the Professional version of PAC Display.
If there are several serial I/O Units configured in a strategy, the PAC Display Runtime scanner may leak network connection handles. This can eventually lead to your PC losing its network and Internet connections when you're running PAC Display Runtime.
