KB86967
Published: November 2, 2017
PAC Control: Table data appears to be blank when you scroll using the mouse scroll wheel
All versions
R9.6e
If you use the mouse scroll wheel to scroll around a table in PAC Control Debug mode, the data that initially was outside the table's frame will appear to be blank when it scrolls into view.
Instead of using the mouse wheel, use the table's scroll bars to navigate around the table.
