KB86972
Published: September 25, 2017
groov log viewer "Advanced Configuration" settings don't take effect immediately
groov View running on:
- GROOV-AT1, GROOV-AT1-SNAP
R3.3a through R3.4b
R3.4c
When you change the groov log viewer's "Advanced Configuration" settings and save them, it appears to work. But changes don't take effect until you restart groov View.
If you look in the Event log, you'll see this error message:
2017-09-20, 10:30:15 GMT-07:00 ERROR com.opto22.groov.server.GroovServletContextListener - /var/lib/jetty/optoapps/loglevels.properties/loglevels.properties (Not a directory)
Restart groov, and the changes will take effect.
