KB86979
Published: November 28, 2017
groov View reports errors for SNAP PAC controllers, but controllers look fine in PAC Control
groov View running on:
- GROOV-AT1, GROOV-AT1-SNAP
R1.0a through R3.4b
R3.4c
One or more SNAP PAC controllers start reporting errors in groov View, typically after a network interruption of some kind. If you check these controllers in PAC Control, they appear to be fine, but groov continues to see errors.
groov logs show repeated communication errors while trying to read a CONTROL_ENGINE tag, with positive numbers in the error code field.
Restart groov.
