KB86987
Published: November 5, 2017
PAC Display: Index column and column titles are missing from table
All versions
R9.6f
When configuring a table in PAC Display Configurator, if you delete the text in the Index Column Title field (Edit > Dynamic Attributes), the Index column and all column titles are hidden. In addition, the first column in the table resized to the width of the table, making it appear that the table has only one column.
When the table is viewed in Runtime, the Index column isn't visible. Other columns are visible but their titles are not displayed.
Instead of deleting the text in the Index Column Title field, select the Use Relative Offsets check box. This will hide the Index column but display the column titles in Runtime.
