KB86994
Published: October 16, 2017
groov Admin update fails if file is renamed
GROOV-AR1-BASE
GROOV-AR1
GROOV-AR1-SNAP
groov Admin 1.570.46 and lower
groov Admin 1.570.47
When you try to update groov Admin, the update fails with the following message: "Failed to update from uploaded file: Unable to verify package signature."
This issue occurs only if you have renamed the update file.
Don't rename the update file; leave the filename as it was when you downloaded it.
