KB87006
Published: November 5, 2017
PAC Display Configurator may crash when you repeat an undo (or redo) after changing window properties
All versions
R9.6f
After you change a window's properties (Window > Properties), PAC Display Configurator may crash if you perform an undo or a redo twice in a row.
For example: You change a window's properties and then click Edit > Undo (to undo the change to the window's properties), and then again click Edit > Undo.
