KB87050
Published: November 8, 2017
PAC Display Pro: If Operator log is saved to database, can't switch to saving log to file
R9.5a through R9.6e and Beta versions B9.6f builds 0001 through 0088
R9.6f
Note: This issue affects PAC Display Pro only.
If you've configured PAC Display to save Operator logs to a database (Configure > Runtime > Security tab > Log To > Database), PAC Display will continue logging to the database even if you change the configuration to log to a file.
