KB87053
Published: November 14, 2017
groov Admin update v47 fails (or Ignition Edge Status "is in an unknown state")
GROOV-AR1-BASE
GROOV-AR1
GROOV-AR1-SNAP
groov Admin 1.570.47
groov Admin 1.570.48
If you attempted to upgrade to groov Admin 1.570.47, you may see:
- The upgrade succeeds, but when you look at the System Information page, the groov Admin version is less than 47.
- If you're upgrading from groov Admin 45 or earlier, the groov Box may be unable to boot.
- The upgrade appears to have succeeded, but when you check Ignition Edge in your groov Box (groov Admin menu > Ignition Edge), in the Status section, you see "Ignition Edge is in an unknown state."
Opto 22 has resolved this issue in groov Admin 1.570.48.
However, if you attempted to install groov Admin 1.570.47, to resolve this issue you must:
- First, reset your groov Box to factory defaults (see steps in the groov Box User's Guide).
- Then, install groov Admin 1.570.48.
