KB87059
Published: January 3, 2018
Controller may reset when activity through PAC REST API is high
SNAP-PAC-S1-FM
SNAP-PAC-R1-FM
SNAP-PAC-R1-B
SNAP-PAC-R2-FM
PAC firmware R9.5a through R9.5f
R9.5g
Note: This issue affects only SNAP PAC S- and R-series controllers that are configured to use the PAC REST API.
SNAP PAC S- and R-series controllers may reset when API requests are constant and continuous—for example, when a Node-RED flow uses the SNAP PAC nodes to repeatedly get or update values in the controller.
