KB87066
Published: November 21, 2017
PAC Control: "Undefined command" error when downloading strategy
PAC Control Basic
PAC Control Professional
R9.5a through R9.6d
R9.6e
If you remove all the nested subroutines in an existing strategy—or if your strategy doesn't have any nested subroutines and you add one or more nested subroutines to it—when you try to download the strategy, PAC Control may display an "Undefined command" error.
If you remove all nested subroutines in a strategy, or if you add one or more nested subroutines to a strategy that previously didn't have any nested subroutines, you should click the "Compile All" icon (or, from the PAC Control menu bar, select Compile > Compile All) before downloading the strategy.
