KB87078
Published: February 16, 2018
Browser Configurator: E1 and E2 brains read and write to the wrong points
OptoOPCServer
R9.6a. Lower versions may be affected also
When you add points from an E1 or E2 brain to a Browser Database, Opto Browser Configurator assigns ID numbers incorrectly to the points. As a result, when you access one of those points, the brain may read (or write to) the wrong point.
