KB87082
Published: February 24, 2018
PAC Display Configurator incorrectly identifies blank entries in recipe download files as "invalid"
R9.0a through R9.6f and Beta version B9.6g Builds 0001 through 0094
If your recipe download file has blank entries in some of the download fields, PAC Display may incorrectly indicate that the file has errors when you validate the file (Tools > Validate Recipe File).
If you're sure your download file is formatted correctly, you can ignore the warnings. The download will succeed in Runtime.
