KB87106
Published: February 24, 2018
PAC Display Configurator: Sometimes Find and Replace does not display drop-down options for Item Name
R9.6f Lower versions may also be affected.
In PAC Display Configurator, sometimes you can't use the Find and Replace function (Edit > Replace) to search for Item Names, because the drop-down lists for "Find what" and "Replace with" are blank.
Try closing and then reopening the Find and Replace dialog box. Sometimes when you reopen it, the item names are displayed correctly in the "Find what" and "Replace with" drop-down lists.
