KB87145
Published: March 14, 2018
groov View forces you to change your password every time you log in
groov View running on:
  • GROOV-AT1, GROOV-AT1-SNAP
R3.4c (Lower versions may also be affected)
R3.5a
Every time you log in to groov View, a message prompts you to change your password (even if you've already changed it).
Opto 22 recommends users follow these steps:
  1. Log in to groov View as an Admin user.
  2. In groov Build, select Configure > Accounts.
  3. Click the Edit (pencil) button for the operator having this issue.
  4. On the Edit user dialog box, UNcheck "Require password change at next login."
  5. Then click Update User.
Now the operator should be able to log in without being prompted for a new password.
