KB87168
Published: April 12, 2019
FTP command redirecting output of a “Dir” command to a specified local file or table returns null at end of each line
PAC firmware for:
SNAP-PAC-S1-FM
SNAP-PAC-R1-FM
SNAP-PAC-R1-B
SNAP-PAC-R2-FM
PAC firmware, all versions prior to R10.0f
PAC firmware R10.0f
An FTP command that redirects output of a “Dir” command to a specified local file or table returns null at end of each line (0D 0A 00 at the end of each line, rather than 0D 0A). An example redirecting output to a string table:
nFileCount = SendCommunicationHandleCommmand( chFTPLocal, “dir:/sdcard0, stFileNames” );
In this example, a subsequent ReceiveStrTable command following the SendCommunicationHandleCommand gives a timeout error.
Instead of the single command, use three commands. For this example:
nFileCount = SendCommunicationHandleCommmand( chFTPLocal, “dir:/sdcard0” );
SetEndOfMessageTerminator( chFTPLocal, 0 );
nStatus = ReceiveStrTable( nFileCount, 0, stFileNames, chFTPLocal );
