KB87205
Published: May 24, 2018
PAC Display Runtime: When you edit a value in a table, sometimes the wrong element is changed
R9.5f through R9.6g
R10.0a
NOTE: This issue occurs only when a table object is configured with the Use Relative Offsets option, and tables in the object are configured to allow edits.
Sometimes when an operator edits a value in a PAC Display Runtime table, the wrong table element is changed. (Note that the changed element is always further down the table than the element the operator wanted to change.)
