KB87208
Published: May 24, 2018
PAC Display Runtime: Can't edit some of the values in a table object
R9.5f through R9.6g
R10.0a
NOTE: This issue occurs only when a table object is configured with the Use Relative Offsets option, and tables in the object are configured to allow edits.
During Runtime, operators can edit values in the first (that is, the leftmost) table in a table object, but in other tables in the same object, they can edit only those values that do not share a row with a value in the first table.
