KB87243
Published: May 24, 2018
Saving a project may cause PAC Display Configurator Pro to hang if Primary Scanner Node field is blank
All versions through R9.6g
R10.0a
Note: This issue affects PAC Display Professional. It does not affect PAC Display Basic.
If the Primary Scanner Node field is blank (Configure > Control Engines > Add or Replace), PAC Display Configurator Professional may hang when you save the project (the spinning "progress" wheel won't stop spinning).
In the Control Engine Properties dialog box (Configure > Control Engines > Add button or Replace button), don't leave the Node field blank. If you don't have a primary scanner, type This Computer in the Node field.
