KB87292
Published: May 24, 2018
PAC Display Configurator does not save configured recipe directories if they are entered manually
R9.3b through R9.6g; also Beta version B9.6h, all builds through Build 0112
R10.0a
When configuring a recipe upload or download file (Configure > Recipes >Add), if you manually type the file path you want in the Directory field, PAC Display Configurator does not save the information. (If you reopen the dialog box, the Directory field will be blank.)
Similarly, if you edit an existing Directory field by typing the file path (Configure > Recipes > Modify), when you close the dialog box, PAC Display won't save your changes.
Instead of manually typing the path in the Directory field, use the Browse button to locate the folder you want.
