KB87305
Published: May 24, 2018
PAC Display Runtime crashes when opening a project that has a string table tag with no index
R9.5a through R9.6g and Beta version B9.6h, all builds through 0112
R10.0a
If you use Quick Tag Entry to configure a tag in a string table—but you forget to configure the tag's index—PAC Display Runtime will crash when it tries to open the project.
When using Quick Tag Entry to configure a tag in a string table, be certain to manually enter the index in brackets in the "Field / [Index]" field.
For example:   [0]
