KB87314
Published: May 24, 2018
PAC Display Runtime displays -1 priority for detailed alarm
R9.0a through R9.6g; and Beta version B9.6h, all builds through 0119
R10.0a
Note: This issue applies only to Detailed Alarms—not to History Alarms.
When looking at a Detailed Alarms window in PAC Display Runtime, you may see an alarm with a Priority of "-1"—even though the alarm was configured with a valid Priority value. This can happen when the alarm point was configured:
- For a discrete point (Configure > Alarm Points > Add or Modify > Setup tab > Setup By > Discrete)
- With "Show Warning State" selected (Configure > Alarm Points > Add or Modify > Setup tab > Show Warning State)
- With a persistence time (Configure > Alarm Points > Add or Modify > Discrete tab > More)
Do not check "Show warning state" when configuring detailed alarms with a persistence time.
