KB87361
Published: November 15, 2019
Text doesn't appear for integer or string Value gadget with format field configured with extra text
groov View running on:
- GROOV-AT1, GROOV-AT1-SNAP
All versions
In groov View, if you configured a Value Gadget with an integer or string tag, and then added fixed text in the Format field (as in the following example), when you run the project, groov View does not display the fixed text:
You can add a Line Header gadget next to the Value gadget to display the fixed text.
