KB87382
Published: November 22, 2019
Can't add a recently created user to a group
groov View running on:
  • GROOV-AT1, GROOV-AT1-SNAP
  • GRV-EPIC-PR1
R1.0.0 to current for GRV-EPIC-PR1
R3.5b to current for all others listed
In groov View, when you edit a recently created user, if you add them to a group through the Edit User dialog, the user is not added to the group.
Instead of adding the user through the Edit User dialog, add them through the Edit Group dialog. (In groov View Build mode, click Configure > Accounts > Groups, then click on the pencil icon of the group you want to add the user to.)
