KB87424
Published: June 13, 2018
No warning generated in error queue if strategy I/O configuration does not match physical I/O
1.0.0-b71
This problem affects strategies running on a GRV-EPIC-PR1 that accesses I/O modules mounted on the same chassis. If the strategy specifies a groov module channel type that is not supported by the physically installed groov module, no -35 (I/O point mismatch) warning is generated in the control engine message queue. This warning should be generated each time the strategy is executed.
Make sure I/O configuration in strategy matches physical I/O configuration.
