KB87507
Published:
Revision: 1.1
Can't access USB-to-serial converter from Node-RED
1.0.0, 1.0.1
1.1.0
If you have Node-RED logic that attempts to access a serial port on a USB-to-Serial converter (for example, /dev/ttySer0), it will fail and display a message similar to the following in the debug tab of the Node-RED editor:
6/7/2018, 5:51:28 PM
msg : string[89]
"serial port /dev/ttySer0 error: Error: Error: Permission denied, cannot open /dev/ttySer0"
