KB87521
Published: October 24, 2025
PAC Control I/O Channel Inspect and Edit dialog boxes may not open from Strategy tree after moving I/O modules
PAC Control Basic
PAC Control Professional
R10.0a to R10.5c (may affect previous versions)
R10.6a
This issue occurs after you perform the following steps:
- In PAC Control, enter Debug mode to download your strategy and return to Config mode.
- Move a module or point (channel) to another location by clicking Move To or Scan for New Modules (groov I/O units only) as described in The Configure I/O Modules and Points Dialog Box section of the PAC Control User’s Guide (Form 1700).
- Save your strategy.
- From the Strategy tree:
- In Config mode, double click on the moved I/O point (channel) to open the Edit Point dialog box.
- In Debug mode, double click on the moved I/O point (channel) to open the Inspect dialog box.
You may see one of these symptoms:
- The Edit Point or Inspect dialog boxes may not open.
- The Edit Point or Inspect dialog boxes may display information for a different channel (point).
There are a few possible workarounds:
- Save, close, and reopen the strategy.
- Edit a moved point (channel) from the Configure I/O Modules and Points window (not from the Strategy tree).
- Rename the points (channels) that were moved.
