KB87526
Published: June 28, 2018
PAC Display may close if you uncheck a dynamic attribute (new Graphic Dynamic Attribute dialog box)
R10.0a
R10.0b
Note: This issue affects PAC Display Configurator only when you're using the new Graphic Dynamic Attributes dialog box in R10.0a.
PAC Display Configurator sometimes closes without warning if you configure a tag using the new Graphic Dynamic Attributes dialog box in PAC Display R10.0a, and then check and immediately uncheck the attribute's check box. Note that this issue happens if you don't click OK before unchecking the attribute's check box.
