KB87533
Published: June 28, 2018
PAC Display Configurator may close when adding an "Execute Menu Item" dynamic attribute using the old-style dialog boxes
R10.0a and Beta version B10.0b, all builds through 0011
R10.0b
When the "Use Older Dynamic Attribute Dialogs" feature is enabled (File > Configurator Options), PAC Display Configurator may close without warning if you try to add the operator-driven Execute Menu Item dynamic attribute.
Use the new Dynamic Attributes dialog box to create Execute Menu Item attributes. You can easily switch between the new and old Dynamic Attribute dialog boxes by selecting and deselecting the Use Older Dynamic Attribute Dialogs feature (File > Configurator Options).
