KB87543
Published: June 28, 2018
PAC Display Runtime can send an out-of-range value to a float variable after a period or minus sign is entered
R9.6g through R10.0a
Lower versions may be affected
R10.0b
When a graphic object is configured to update a float variable using the Send Value dynamic attribute and the Prompt for Data, Min Value, and Max Value options, PAC Display Runtime will erroneously send an out-of-range value if the operator first enters an out-of-range value and then enters a period ( . ) or a minus sign ( - ) at the prompt.
