KB87547
Published: June 28, 2018
Editing an OptoScript block containing a long string literal without spaces may cause PAC Control to crash
PAC Control Basic
PAC Control Professional
All versions through R10.a
R10.0b
PAC Control may crash when you try to edit an OptoScript block containing a string literal that is longer than 63 characters and has no spaces. This may happen regardless of whether the OptoScript block is a chart or a subroutine.
This issue presents a stack-based overflow vulnerability that can be exploited by an attacker to remotely execute code on the target PC using a maliciously crafted PAC Control strategy.
NCCIC has assigned CVE-2018-04154 to identify this vulnerability.
