KB87557
Published: November 14, 2019
Changed properties of configured Modbus tag do not take effect
groov View running on:
- GRV-EPIC-PR1
- GROOV-AT1, GROOV-AT1-SNAP
All versions
In groov View, after you create and save a Modbus tag, if you edit it again to change any property, the changes do not take effect.
Delete the tag and re-create it with the correct settings.
