KB87702
Published: December 23, 2020
IVAL Value Does Not Update in I/O Unit Inspecting Window
- PACCONTROLBAS (PAC Control Basic)
- PACCONTROLPRO (PAC Control Professional)
R10.0b to R10.3c
R10.3d
For the following sequence of events, the IVAL value does not update in the I/O Unit inspecting dialog box:
- Configure a PAC Control strategy with the I/O unit setting "Enable communication from control engine" unchecked.
- Switch to Debug Mode, download and then start the strategy.
- Double-click on the I/O Unit to open the inspecting I/O Unit dialog box.
- Double-click on the configured point to open the inspecting point dialog box.
- In the point dialog box, change the state of the IVAL and click apply. You will notice that the state will not update in the I/O Unit dialog box.
Edit the I/O Unit to check (enable) the "Enable Communications from control engine" setting before you download the PAC Control strategy.
