KB87729
Published: February 14, 2019
If multiple Control Engine devices are used on a single IP address, but on different ports, one device going offline causes errors in others
GRV-EPIC-PR1
GROOV-AR1
GROOV-AR1-BASE
GROOV-AR1-SNAP
GROOV-SVR-WIN
GROOV-SVR-WIN-BASE
GROOV-SVR-WIN-SNAP
groov View R4.0d and lower
GRV-EPIC-PR1 firmware 1.2.2 and lower
groov View R4.1a
GRV-EPIC-PR1 firmware 1.3.0
If you are using multiple Control Engine devices on a single IP address, but on different ports, and one of the devices goes offline, you will see errors on the other devices.
Note: This only applies in this particular case: multiple control engine devices sharing the same IP address but listening on different ports.
