KB87747
Published:
Revision: 1.1
PAC Display Configurator: Canceling Alarm Configuration window erases alarm points
PAC Display Configurator Basic
R9.5a - R10.1b and beta builds through B10.1c Build 0021
R10.2a
In the Alarm Configuration window, if you click Cancel after adding some alarm points, the next time you try to add alarm points to the same alarm graphic, the alarm points  that were listed in the Alarm Points window disappear.
  • Delete the alarm graphic and create a new one. When you add alarm points, the missing alarm points reappears in the Alarm points window.
  • Close PAC Display Configurator and then restart it.
