KB87749
Published:
Revision: 1.1
PID not configured after running EnableCommunicationToPidLoop instruction
Firmware for:
- SNAP-PAC-S2, SNAP-PAC-S2-W
- SNAP-PAC-R1, SNAP-PAC-R1-FM, SNAP-PAC-R1-W, SNAP-PAC-R1-B
- SoftPAC
All PAC Firmware versions through R9.5h
PAC Firmware R10.0d
When you check the PID information in PAC Manager, none of the configuration information is there. This happens when you do the following:
- Add a PID loop to your strategy, entering all the information, but deselect the "Enable Communications" check box
- Add the
EnableCommunicationToPidLoop() instruction to your strategy to enable that PID loop.
- Run your strategy.
