KB87797
Published:
Revision: 1.1
PAC Display Configurator: Sub-attributes of Send Value, Discrete, String do not retain modified values
PAC Display Configurator (Basic and Professional)
R10.0a-R10.1a and B10.1b all builds through 0023
R10.2a
You'll see this issue if:
  • you are using the all-in-one Graphics Dynamic Attributes dialog box (introduced in PAC Display R10.0a), and
  • you are making a change to a sub-attribute of the Send Value, Send Discrete, or Send String attributes.
When you click OK to save your changes, the next time you open the Graphics Dynamic Attributes dialog box, those changes will not appear.
To save your changes, use the older dialog boxes. To access those older dialog boxes, click File > Configurator Options > Use Older Dynamic Attribute Dialogs.
