KB87818
Published: June 14, 2019
Strategy archive fails if Watch Window files can't be found
10.0a through 10.2a
R10.2b
When you archive a strategy, you see a message similar to the following:
This usually happens if the file is not included in a zip file of strategy files; it can also happen if you delete the watch window file (a file with a *.wth extension) from the strategy folder.
Go into Debug mode and attempt to open each Watch Window. Any Watch Windows that aren't found will be removed from the recently used list, so they will no longer be referenced in the strategy. This will allow the strategy archive to succeed.
If you are creating a zip file of the strategy, use File > Archive Strategy in PAC Control to ensure all files are included.
